I've purchased a used RV with a Wineguard Roadtrip Minimax automatic dome satellite antenna. I'm attempting to install a Directv D12-500 SD box. The antenna is set for Directv (1-7up, 8 dwn). I seem to be in a catch 22 situation as Wineguard says if it doesn't find the satellite, then the box is set up wrong. But to set up the box, it needs a satellite signal. I've followed Wineguard's 12 step process, including selecting a 3-LNB 18x20 dish and multi-switch in step 5, but it doesn't verify in step 6. If I force through to step 9, it never downloads, because the antenna is not pointed at a satellite. What am I missing? BTW, the box works fine in the house, but that is a SWM setup. I've removed the dome and the antenna rotates 360 degrees and goes up and down as it searches, just never locks in on a signal. There are no obstructions to the southern sky.
