Hey, got any link to that interview from Phil Goswitz?Not so much a rumor. This was mentioned last year when Phil G was with ATT that T16 and T17 were on order in an interview. If I remember right one is going to 119 to replace D7S as that has had some issues in the past and the other is going to 101 to support the MPEG 2 shutdown that is upcoming. We should eventually see everything go to MPEG4 HD on the 101 opening up more room for National HD.
Also, all of DirecTV's satellites are called T - whatever. IE T14, T15, T16, ect. I guess when you buy out a company you get to rename the satellites!
And is he no longer with AT&T/DIRECTV? Didn't know that ...
I've been checking the FCC site regularly for any postings of an LOA ("Launch and Operate Authority") filing for "T16" (wasn't aware there was a "T17" on order). But still nothing after all this time, which is very strange since the submission of an official LOA usually precedes the actual construction of a satellite.
Wow ... launch scheduled for later this year, which means the bird is either completed or nearly so, and nothing at all filed with the FCC on it so far ...Yes, he retired. I really like Phil. He's an awesome guy. According to this, Space Assigned Numbers Authority (SANA) T16 scheduled for August. I'm trying to find the article but can't seem to find it either. It was on one of those TV news websites that cover the industry. Maybe ATT put a halt on T17 or it ended up never going on order.
As I say, ... very strange ...
How can AT&T even be sure the Feds will even approve it, and not object to something about its design?
I doubt they would go ahead and build it if it wasn't already ok'd ...Wow ... launch scheduled for later this year, which means the bird is either completed or nearly so, and nothing at all filed with the FCC on it so far ...
Higher power would make sense.I don’t think a new satellite can make a difference unless they tighten the spot beams. Or Go higher power to reduce rain fade
The likely speculation is that DIRECTV is going to phase out all Ku band spotbeams on 101° and 119° and use all 32 DBS tp. licenses at 101° and 11 at 119° for CONUS wide beams on new satellites. Possibly with spotbeams to mirror all CONUS tps. to Hawaii and PR like T15's DBS Ku band payload is capable of.I don’t think a new satellite can make a difference unless they tighten the spot beams. Or Go higher power to reduce rain fade
... I wonder what the payload would be? Ku with a possible ka / rb payload? Can the current LNB’s do that? I would think this would match what’s currently in orbit.
The current LNBs can only receive the DBS Ku band from 101°, 110°, and 119°W. And the Ka and RB from 99° and 103°W
Yea your right. If they do indeed go to an all 32 conus configuration between both slots 101 and 119 that would give them plenty of space. As far as I know anything that is on those spots are SD. Why not just drop them and all SD spots all together and go strictly MP4 HD/SD off the 103/99. If they retired all of the SD spots they could repurpose those later for ATSC 3.0 Local content with a modulation change for increased bandwidth. Sound plausible?
I have a KU only In-motion Satellite Dome on my boat, I had it installed 2 years ago. I have an extra D-12 which I keep at my boat in the summer. I guess the question is what will KU service look like for my KU only Dish on my boat. My Boat system switches between 101 (Core SD Service) and 119 for my Local Market channels (Rochester NY). If KU service from 101,119 ends up as only partial Core service and no Local Service I might have to consider Dish Network at my Boat. I know it is early in this process, any light anybody can provide would be helpful.
KA in Motion equipment for my Boat is just cost prohibitive for me.
John
