I have been trying at this for 2 weeks and still have had no luck. I need help setting up a multiswitch for my Samsung 4120 Directivo.
Here the situation:
I have an oval, 3-LNB dish that was installed in my apartment prior to me getting here. There are FOUR cables coming out of the dish - (keep in mind its 3 LNB) - two are into the living room, one to each bedroom. THEY ALL WORK INDIVIDUALLY WITH THE SAME RECEIVER WHEN TESTED (just to show you each input works).
The problem is in my living room. I have a Samsung 360 HD Receiver and a Samsung 4120 Directivo. If I plug both LNB sources into Sat 1 & 2 of the Tivo - works perfectly. If I plug either LNB direct source into the HD receiver, works each time. If I plug one into Sat 1 of the Tivo, and one into the HD - works great. You get the idea.
So I bought a 2x4 Multiswitch. I plugged one LNB direct source into LNB 1 input on the switch; LNB direct source two into LNB 2 on the switch.
RX1 output into Sat 1; RX2 into the HD; RX3 into Sat 2; RX4 is just plugged in (extra receiver is plugged in on Sundays for football).
During the "Test Signal Strength" portion of the Directivo setup, it finds all three satellites 101 A; 119 B; 110 C. On most transponders it is getting a good signal (between 80-100) and it's getting something on each one.
Then I proceed to "Confirming Setup" and it says:
Multiswitch: None
Satellites, Sat in 1: 101 (A): ok; 119 (B): not detected; 110 (C): not detected.
Satellites, Sat in 2: 101 (A): ok; 119 (B): not detected; 110 (C): not detected
WARNING! A problem was detected.
I am stumped. I tried several forums and they describe this type of setup with a 2x4 switch, and still I have no success. Please give me some good help overnight!
Thank you
BeerMan
Here the situation:
Multiswitch: None
Thank you
BeerMan
