For anyone researching a new set of speakers, this FAQ should come in handy in deciding between Di/Bi- Polar speakers for surrounds or a direct driving monopolar speaker.
Dipolar refers to speakers with drivers that are fired in two different directions and are in reverse phase causing a cancellation of sound waves in front of the speaker. This is usually done in rear speakers that are wall mounted. The front of the speaker is aimed at the listening area, which causes all of the sound to bounce off the walls before it is heard. This makes it almost impossible to determine where the speaker is, creating a true surround effect.
Bi-polar refers to speakers with drivers that are fired in two different directions, but are in phase causing an increase in bass output. I this type of speaker the drivers can be in the front and back of the speaker, side firing, or at 90º angles from one another. There are also speakers which function as both bipolar and dipolar. This can be adjusted using a switch.
Monopole is a type of speaker with all drivers facing one direction. Used for precise placement of sounds. Usually used in front and center speakers.
