I know that diplexing OTA does not work on the Hopper feed. But, what about the Joey feed? I thought I remembered that the Joey uses a narrower frequency range that doesn't overlap with OTA freqs.
Do you think the add'l streaming content would be too much for a solid wi-fi N connection to handle?
Plus, it would only be on those occasions where the additional tuners are being used.
Does it use a dual node like a two Hopper setup?The Super Joey requires coax because it is connected directly to the LNB by the coax. So it cannot work by wifi.
It uses a solo node and an "Integrator" which is basically a type of diplexor. 3 lines from the dish, two to the node, one to the integrator, the integrator hooks to the node's client port, then the other side of the integrator goes to the SJ.Does it use a dual node like a two Hopper setup?
I see. So, I'd have to run a 3rd line from the switch. That's easy, if I ever decide to upgrade.It uses a solo node and an "Integrator" which is basically a type of diplexor. 3 lines from the dish, two to the node, one to the integrator, the integrator hooks to the node's client port, then the other side of the integrator goes to the SJ.
The Super Joey will actually work on the other host port of the duo node. It's just not a "supported" method. I believe the main reason they went with the solo node/integrator option is because the bean counters figured out that it would save a few dollars per install. Just connect it directly to the host port, no integrator required. Take note that, just like in two-Hopper setups, the duo node will require three lines from the dish in order to work.
But, doesn't a solo node only have two inputs from the dish, and the SJ requires three (according to folks above)?Are you sure about that? I know the sjoey will work on the CLIENT port of a solo node without an integrater, why wouldn't it be the same on a duo node? And just make sure any open ports are capped off..
I know. I recently moved mine during a rewiring project at home.Yes, yes it does. Two coax inputs and a Client and Host output.
