digiwave 8x1
janzy
SatelliteGuys Guru
126
will an uncommited 8x1 disecq switch work in DVBDream?
If so, how do I set it up?
Yes, Raw commands is the easiest way I know.
Uncommitted CMD 0 raw command E0 10 39 F0
Uncommitted CMD 1 raw command E0 10 39 F1
Uncommitted CMD 2 raw command E0 10 39 F2
Uncommitted CMD 3 raw command E0 10 39 F3
Uncommitted CMD 4 raw command E0 10 39 F4
Uncommitted CMD 5 raw command E0 10 39 F5
Uncommitted CMD 6 raw command E0 10 39 F6
Uncommitted CMD 7 raw command E0 10 39 F7
0 to 7 = 8 ports
Jerryt,
I'm having a problem setting this up. Only 1 sat is showing up.
Can you tell me how to do the setup in DVBDream?
For diseqc switch select "None"
Add all the satellites you want, they will show as if attached to one LNB.
Add the proper raw diseqc command for each satellite; "E0 10 39 F0" etc...
Which card are you using?
Need help Choosing Satellite dish package
Creating back-up of receiver data?
