I have good reception of DVB-S across the arc from 125 W to 72 W. I receive the PBS HD on 125 W with no problem. I have 90 CM GeoSatPro Dish on DG380, 0.3 db LNBF, Pansat 9200HD. I purchased the Pansat used and it came with 8PSK module, I think is the Illuminati model. I have not been able to set up and receive any DVB-S2 signal. The options are available in the Pansat menu, but I obtain no results. I have been trying to get the NBC HD on 103W AMC 1 11880 H 30000.
So my questions are:
Is my system insufficient, such as dish size too small? I will eventually upgrade to 1.2 meter.
Is the 8PSK module defective or insufficient? If it is not usable, I will consider upgrade to Pansat DVB-S2 PLUS module. However, I may get the AZBOX at the end of the year and use the Pansat as a second room receiver.
I would like to get as much as I can out of the system that I have.
Thanks,
Thanks,
