Hey guys, long time/returning customer. I now fulltime live in a RV so, we travel around a lot. I have a Slimline dish with a 3 lnb SWiM "head" , power inserter etc. I also have my original 5 lnb non-SWiM "head".
The problem I'm having is, when I set up my dish with the non-SWiM, & use my inline signal finder, I can usually find the 5 sats. fairly quickly and then "fine tune" using the rf dial & tone from the inline sat. finder.
When I try to find the sats. with the SWiM head in place, my inline sat. finder/meter seems to be useless. The tone and meter don't change while looking for the sats. I get the same steady tone no matter which direction/angle I move the dish. But, not so when I do the same with the non-SWiM mounted.....I find sats. easy that way.
Am I hooking my meter in the wrong place? Do I put it inline before or after the power inserter?
The only reason I'm getting away from the 5 lnb non-SWiM setup is so I only need 1 coax from the dish & because it is starting to loose reception of most of the transponders periodically. When this happens, I have to go out and change my coax to one of the other 4 leads from the 5 lnb. It seems that doing this, "resets" everything and all works ok for awhile until I notice I'm loosing channels.
Any advise would be appreciated.
Sorry guys, I wasn't quite awake yet and just realized my correct terminology for "HEAD" should be "switch". Ok, I'm awake now!!!!
