>My DSR 405 has S video out, so does my 922. I don't think 410's have S.
>The composite out on the 4DTV and 410 gives a very decent picture.
>If it don't look good you need to look at your cables or see if the scaler in you HDTV is crap.
>My Sharp Aquos scaler does a good job converting to 1080p native from 480i.
Ok, I see below as well that there are in fact two versions. Just wondered because I thought my previous unit had an s-video port.
Nothing wrong with the TV, it runs everything I've thrown at it to date, it's that I'm putting together a new setup in how I'm getting HD to other areas of the house.
>The only difference between composite and S is with S.Y luminescence (brightness) and C chroma (3.58mhz color burst are separate).
The separate signals are a better input for the switch I'm using. Though, I don't know for sure since visually, it's never made much difference.
I've got all of my sources running through an extron system 7sc as a switcher in the basement for a final output of component which I'm able to extend to an HD TV via CAT5 in another area of the house. Just trying to get the best signals I can with the stuff I've got from past projects. I never saw anything about HD channels on 4DTV either so assumed there aren't any.
