Dbs is also affected by rain fade but it’s better now then it used to be in the late 90’s when it started.
Plus they use higher frequencies
They use a higher frequency then we use for fta.
What about 121? Isn’t that a Dish bird that uses regular Ku?
it is... While is it quite powerful it's definitely less powerful than the other dedicated DBS birds. That's why they had the slightly larger dishes like the "superdish" which is about 60cm. And Dish on 121W seems to be barely used these days, I think it's mostly for specialized services (where they might be able to still push for larger dishes compared to the average DN setup)What about 121? Isn’t that a Dish bird that uses regular Ku?
It uses Ku band (11715-12171) but with linear polarity and lower power -- hence the larger Superdish.What about 121? Isn’t that a Dish bird that uses regular Ku?
