Would there be a big increase in signal quality with a 100 cm dish over a 90 cm? I'm getting ready to set up a couple of stationary dishes and the 1 meter dish is only about $30 more. Any input would be appreciated.
Some guys with small dishes are having adjacent-satellite interference on a few birds.
From what I've seen, the 90cm takes care of the problem.
You might list which satellites you are interested in, and get feedback on whether or not there is a problem.
Obviously, the 100 should be a little better than even the 90 .... on paper.
But maybe save the 100 for the problematic birds, and go with 90's for others...?
I remember a Fortec 90cm review by Iceberg a few years ago.
That convinced me to not touch anything smaller.
Of course, if you are out of footprint in "The Land of Enchantment", then bigger is always better.
No HOA here. I think I'll go for the 100cm dishes. I'm doing a group buy with a few locals that want to get into FTA. They have left the decision up to me. It's going to be fun to play with multiple LNB's on a 1 meter. I know 10 degrees to either side is common but I'm going to see if I can get more just for fun.If you can afford the price difference (30$ does not sound that bad) then I would recommend that you go with the 100cm. (The largest dish you can easily get away with if you are in a HOA, unless you the VP of the HOA like Iceberg )
When I upgraded from a 80 cm dish to a 90 cm dish I saw a huge improvement, I was slightly disappointed that I could not pick up some of the weaker feeds so I finally upgraded to a 120 cm dish which I am very happy with.
Two other things to consider, do come to mind:
1). shipping on anything bigger than 36" dishes usually gets silly.
Could be $20/30 extra. Just verify the overall cost so you know what you're getting into
2). last year, JsatTV up in Canada, had some trouble adjusting elevation on his Fortec 1.0 dish.
When you loosened the hardware, the dish just flopped around.
Also, it didn't seem to have a real pivot bolt for elevation, making it even harder to adjust.
What we came up with was a mod to add an elevation pivot, and a screw adjuster for fine tuning elevation.
The 90's in most all brands, do have a pivot pin/bolt.
Unfortunately, nobody has a screw elevation adjuster, 'till you get to 120cm, and then only the GeoSat does, of the inexpensive dishes.
This gets more critical as you move into the larger and heavier dishes.
I'll dig out the links to the discussion with JsatTV from last year, if you're interested in reading 'em.
Could be $20/30 extra. Just verify the overall cost so you know what you're getting into.
These is a simple solution to this. I even did it on my 3ABN 90cm. I just used a couple of c-clamps, a turnbuckle and a couple of ez-links. Clamp on the turnbuckle, make your adjustments, when everything is tightened down on the dish mounts remove the c-clamps and turnbuckle. A re-adjustment takes me about 3 minutes to set the rig back up again.2). last year, JsatTV up in Canada, had some trouble adjusting elevation on his Fortec 1.0 dish.
If it's not too much trouble I would like to read them.I'll dig out the links to the discussion with JsatTV from last year, if you're interested in reading 'em.
But you are right about the Primestars ... though, they may well be the most inexpensive of all!
Well, that makes it all the more attractive.The $30 premium from the 90 to 100 has the shipping costs figured in.
Sounds great. But, I'm not picturing your setup.I just used a couple of c-clamps, a turnbuckle and a couple of ez-links.
I hope these links fully cover his troubles.If it's not too much trouble I would like to read them.
