Did I miss the window for VOD?
pmalve
219
I just got my hr 20-700 yesterday. Am I out of luck for testing the VOD?
You needed to download the x0190 release of DoD and enable it in that version only. So if you didn't do that then you're out of luck until D* decides to enable a 'secret word' again to enable the feature.
Besides having the proper code on the HR20, D* also needs to enable your account to use DoD, they were doing this by monitoring which HR20's had their network connections active and CE sofware downloaded, so if you haven't network connected your HR20 I'd recommend that you do that ASAP so you'll be ready to go.
best way to network connect...
what is the best way to network connect...can you use a wireless router? If so which is the best one to use...thankx
I you can run a cable that would be best way to connect, if you can't using a wireless 802.11g or greater wireless ethernet adapter would work.
H20-600 / Sep. 7 & 8 / {CE:08:02} - 0x203?
H20-100 / Sep. 7 & 8 / {CE:08:02} - 0x203?
