I just received a new Dell Inspiron 15 5505 laptop, with an AMD Ryzen 4500 processor and Windows 10 Home. The only configuration comes with an m.2 256gb ssd in slot 1. You can't buy it with a larger one directly from Dell. There is a second slot for another ssd that you are supposed to be able to install at the same time.
Anyway, I bought this ssd for the second slot: Amazon product ASIN B07YFFX5MD
I installed it, and the Dell's BIOS can see it in slot 2 just fine. I boot into Windows, bring up Disk Management, and you can see it as Disk 1. If you click on that to "Initialize" it, then click OK, it says: "Drive doesn't exist" (paraphrasing).
I have NEVER dealt with or installed an ssd drive before, and don't know if I'm doing something wrong, if this ssd is somehow incompatible with my system, (even though BIOS can see it) OR if it's just bad. In the interest of full disclosure, and if it makes any difference, when I first booted up this laptop and did initial setup, it installed something called "Bootlocker" on the C: boot drive, which apparently encrypts the drive.
I don't need this to replace the original drive, I simply wanted it for a "user drive" to put my user files on.
Any ideas?
Any ideas?
