Deleting recordings
Lawrence Seeley
Penfield, NY 14526
I have the new hopper 3. Some of the recordings won’t delete. When I go to ever then the program, it doesn’t always show the recall to delete. I can only delete some of the recordings. How do I delete recordings that don’t have the press recall to delete option?
Sounds like you have Prime Time Anytime enabled for the big 4 network shows, which can not be deleted until after their "active" expiration date, which by default is 8 days. You can change that to a shorter period in PTAT settings.
If it's recording (Red Dot) it won't have the option. Sometimes I wanna delete a program and it doesn't have the recall ability (I don't have PrimeTime Anytime enabled) I go to the program, select watch, then select 300X, when it gets to the end I delete.
Reactions: HipKat and pattykay
I see that sometimes. If you just press the stop button, you get the option to delete the recording, at least with the 40.0 remote.
Old receivers showing in my equipment
Question about new V 54 remotes
