I vote that the receivers should stay on the list that they were last on before the daily/nightly update.
Maybe the real question is: Whose default favorites list is it?? Yours or Dish's??
If I remember!I just looked and I was incorrect in saying Favorites 1, 2 , etc. It is actually List 1, 2, etc. That said, Gary has proved that the naming of the Favorites list is not the issue fix. Now, the only thing I can think of that is different from what Gary and I have set up is my Auto-tune. Gary, just for more jeepers, set up an auto-tune for ABC7 News at 5AM and see if that fixes it. Doesn't make sense, I know, but you and I are almost set-up exactly the same, same area, western arc, etc... You have the issue, I don't. Something is causing that to happen. Maybe if we can isolate what it is we can get it fixed permanently for every one.
It's definitely de fault of Dish.Maybe the real question is: Whose default favorites list is it?? Yours or Dish's??![]()
If I remember!
But, a workaround really shouldn't be necessary. It should just behave properly, meaning it should always remain on the last guide choice. Period.
The only other acceptable option would be to have a user setting for default guide in the system menu.
I think that Bobby is saying his Hopper never goes into standby mode, as he uses a timer as a keep-alive. And, that is what might be keeping his chosen guide selection intact.So you're saying if you pick any favorites list in the guide, the following day it will still default to that list rather than My Channels? Does your Hopper reboot nightly? What software version do you see if you press Menu Menu?
Bobby said:OK, I went so far as to turn off my Hopper last night before going to bed. I got up this morning and went it directly to my Favorites list that I had it on last night. I do an auto-tune every day after the nightly reboot just to get rid of the need to push select to come out of standby. I did notice that the Hopper was 'on' this morning even though I turned it off last night. So, it appears that turning the Hopper off at night doesn't change anything.
Another day gone by, and the guide is still set to my Favorites. I'm really starting to think they may have fixed this in the 208 sw release, even though it isn't mentioned in the change list.
My vip922 always returned to "My recordings", in the morning...my faves never defaulted that I can remember.
Ahhhh. sorry meant "My Channels"...but you knew that.Could you explain "Return to My Recordings"?
There is no favorite list called "My Recordings"
