Probably true, but 1) that data is likely going to be completely useless to me and 2) monitoring such data may be a violation of
18 USC 2511...under (2)(g) it says "It shall not be unlawful under this chapter or chapter 121 of this title for any person-- (i) to intercept or access an electronic communication made through an electronic communication system that is configured so that such electronic communication is readily accessible to the general public;"
I wonder what they consider "readily accessible to the general public", does a dish, LNB and PCI card count for that?
*edit*
18 USC 2510 contains definitions:
"(16) "readily accessible to the general public" means, with respect to a radio communication, that such communication is not--
(A) scrambled or encrypted;
(B) transmitted using modulation techniques whose essential parameters have been withheld from the public with the intention of preserving the privacy of such communication;
(C) carried on a subcarrier or other signal subsidiary to a radio transmission;
(D) transmitted over a communication system provided by a common carrier, unless the communication is a tone only paging system communication; or
(E) transmitted on frequencies allocated under part 25, subpart D, E, or F of part 74, or part 94 of the Rules of the Federal Communications Commission, unless, in the case of a communication transmitted on a frequency allocated under part 74 that is not exclusively allocated to broadcast auxiliary services, the communication is a two-way voice communication by radio;"
Time to hit the FCC rules to see where the Ku band falls, and check the Communications Act of 1934 to see what the definition of "common carrier" is.
