Daisey Chaining Switches
Dishwhiz
18
Gulf Coast TEXAS
In this procedure, Do all 44 switches need to be the same model? or is there a conflict between oldschool and new (ground type)? for the last switch I used the new Grey 44 and both receivers doing the same thing. Must have an answer Cust. waiting
Jimmerinwi said:
It doesn't matter the type of 44 switch. Old or new can mix.
But you really shouldn't mix legacy and DPP switches or lnbs. And can't mix legacy and DP switches and lnbs. And need to be sure to hook up the power inserters for each of the 44 switches. And of course only connected to port number 1.
you cant mix Legacy and Dish Pro switches/LNB's together
you CAN use Legacy switches and LNB's on a new DishPro compatible receiver
What is current software version on 922?
using 622 as a receiver for OTA locals only
