I have a stock D1000.2 DishPro Plus antenna with the triple LNBF and no external switches.
From my LNBF block, I see 3 outputs + 1 LNB input. I understand that I can get all 3 satellites on any of the three outputs, and there is also some sort of magical separator that Dish connects to my 722vip that actually gives it 2 separate feeds.
Here are my questions:
1) How the *freak* does this thing even work? It seems like a technical miracle to me. Is there a diagram that I can look at that explains the operation graphically?
2) Are there any switches located in the antenna/LNBF somewhere? I don't see any, but it seems like there must be.
3) How do the DiSEqC commands get interpreted? For example, if I have my cable coming to Connection #1 on the LNBF block, should all the DiSEqC commands for 110W / 119W / 129W be going to DiSEqC Port 1, or should each satellite go to a different DiSEqCport?
4) What version of DiSEqC does the D1000.2 support?
Thanks!
AzJazz
Thanks!
AzJazz
