D* tech doing personal E* install.
twizt3dsist3r
2,962
212
Pennsylvania, United States
Hello all, Im a d* tech and have a birdog with all the birds from both companies on it, now im installing a d* system into my moms house which currently has dishnetwork, but were keeping both. The E* setup is pre existing, but i need to move the dish itself for her. My question is what satellites im looking for. The dish is a 'Superdish" and there are two receivers a 625 and a 311 theres also a switch outside on the dish. I can birdog the lines going into the receiver and pick up sat dishnet 110 at 100% on log. but nothing else, im guessing i need to birdog straight from the lnb, but whats the other satellite or satellites am i looking for? Could some kind tech give me a crash course in peaking the superdish?
Basically, you should be looking for 110 & 119. The SuperDish is no longer used. It was used to pick up 105 or 121 along with the 110/119. You should get great SS using the SD for just 110/119.:D
go to the check switch screen on reciever (menue 6-1-1) the screen will tell you what input on the dp 34 each sat in on, unhook the coax off the input for the sat you want to line up hook up your bird dog and peak it in
Comment about remote access and EHD
Want to Move Network to Another Room
