Thanks for the reply. I have a couple of diplexors. Will they work?
Diplexers can work with the HR20 and the 5lnb dish. But not in the normal configuration.
I'm going to assume that you have the one HR20 and two cables coming directly from the dish to the two BBC dongles on the back of the HR20. If you have a multiswitch to feed additional receivers, the procedure is different.
1) Find a spot INDOORS but close to the dish where you can bring a new cable from the dish to a diplexer input. Failing that, you are going to have to figure out how to weatherproof one of the BBC dongles and the diplexer.
2) Remove one of the BBC dongles from the back of the set. Connect the cable to the "combined" side (the single input side) of one of the diplexers. You probably want a "DC block" on the OTA output.
3) Take the other diplexer and the BBC to the point close to the dish. Attach the cable from the dish to the BBC input, and the BBC output goes to the sat input of the diplexer. (the BBC is now between the dish and the diplexer sat input).
4) Take the OTA cable, and a "DC Block" and connect them to the OTA input of the diplexer. Attach the combined output to the cable running into the house.
5) Go back into the house and connect the OTA output of the diplexer to the OTA input on the HR20 (or to a splitter and then to the OTA input). Connect the diplexer sat output to the sat input of the HR20.
Code:
dish -- BBC --| |------------ SAT
diplexer ----- diplexer
ant --- DC Blk| |--DC blk -- OTA
The idea is to allow the BBC to do its job of moving the sat signal out of the UHF band before mixing in the (UHF) OTA signal.
The only caveat is that the distance between the BBC and the HR20 should be a short as possible. 50 feet is thought to be OK.
Note: DirecTV does not support this configuration.
