mini1 said:Ask for the R10. Its currently the best.
JosephB said:Actually, the R10 is not necessarily the best. If you plan on doing any hacking (other than adding a larger hard drive) then you do NOT want an R10. If you do not plan on modifying your Tivo (or if you only plan to add a larger hard drive) then an R10 is fine, and is marginally better than other models.
