Well, you could try to install the 5 LNB on your own, but I highly recommend having an installer out to set it up.
With the 5 LNB dishes "close" is not good enough, they must be dead-on. There is a procedure for "peaking" the dish that the installers follow.
Correct. You might do OK with the Ku stuff on 101/110/119 but the Ka band for 99/103 has a very sharp roll off if it's not aligned right on the money. Also make sure whomever does it that they also install monopole(s) to help support the dish so the wind doesn't knock it out of alignment.
Thanks for the help, do you know anywhere that I can get the 5LNB dish? What is its official name, by the way?
What are the monopoles?
Thanks again guys for all the help . . .
Here's the dish, http://www.solidsignal.com/prod_display.asp?PROD=AU9-S and for the monopole
http://www.solidsignal.com/prod_display.asp?prod=DTVA3-BRACE
Great! What is the difference between the AT-9 and AU-9? Is there a better (easier) one to install? Thanks for the help . . .
Thanks Jimbo . . . Yes, I will be installing myself.
Last question, are the local channels that I will receive based on a spot beam or based on my billing address?
Thanks for all the help . . .
