Correct RG6 cabling.
kelleyga
320
When making a new RG6 cable to connect to the LNBs or the receiver what is the best way to get the best performance:
a) Strip cable, cut foil and cut braid, install connector
b) Strip cable, cut foil and pull braid back, install connector
Or the braid does not make a difference.
buy a cable stripper at lowes
and your answer depends on if you are using crimp/compression or screw on connectors
crimp/compression....it doesnt matter, screw on, pull the braid back...it does matter.
Something on PAS1R KU
Will this work for t5 sat?
