coolsat 6000
draco56
12
Hi
I need 89.0w for true south, My receiver only has 87.0w and 91.0w.
Will either one work?
you can add 89W. Go to dish install and scroll to bottom. There should be a spot to add a satellite.
Add the satellite as IA8 (or G28)
put in the LNB LO and save
then go to manual scan and input an active transponder (there is a thread at the top that says "I need a strong transponder" and that will list one or two
menu
installation is the first option, right arrow to dish setup (top one). I'm not near my Coolsat so I cant give you the exact name of it
went to 0.0e---- rename to 89.0w entered lnb freq does not seem
to work. Can i pick a satellite and change the lnb freq.
colbec
invacom snh-031 lo 9.75/10.6 ghz (ebay)
lnb type single 11.780 to 11.780
Junk or treasure, GI650i
