I tried to add a new SG 2100 motorized mount to my Coolsat 6000 receiver in a homebrewed FTA system. With the motor mounted, but no dish attached, I powered up the setup, but the 6000 seems to keep protecting itself and rebooting. I thought there was a short in the new motor, so I got out an old analog IRD and powered up the motor and reset the motor's memory. I manually moved the motor with no problem, so it isn't jammed (The old IRD doesn't have DiSeqC, so I couldn't try out the remote movements). I checked the current draw and it peaked at about 160 mA (without movement), which is a lot less than the Coolsat is rated for (400 mA).
Has anyone got the Coolsat 6000 to work with the SG 2100? Any ideas where to troubleshoot?
I have checked the coax cable, reflashed the stock firmware and reset the receiver, and checked the dish/mount settings. There is no dish installed right now to load the mount, and the mount is new and moves manually. I don't believe my receiver is a clone as it has a serial number and factory halographic seals. Any idea which component is at fault and any remidies???
