I have a coolsat 5000 and need to update the satellite list so I can get amc 21 and some other new satellites that have been put up since the box was new.
any ideas
any ideas
Renaming is cosmetic, and good to do to keep your sanity, but the necessary data is the LO, lnb type and any switch configurations you might have. As posted delete any 'residual' TP info from the commandeered satellite page and manually input your TP freqs/SR or do a BS if you are sure of all the settings are correct and the dish is aligned properly.so if i wanted 125w and needed to tune to 12179-v-30000 I can rename a sat not in use,
I will try but I did not see a sat that had 12179 available, I will look again.
I did not try the sats east of the Atlantic.
thanks
