Win a SatelliteAV GEOSATpro 1.2 meter dish with SL2 Ku-band and C/KU LNBF with Mounting Bracket! Ends 4/15/2009
Want to experiment with C-band Micro-BUD or have a serious Ku-band system capable of feeding multiple receivers? Enter to win Today!
PLUS FREE SHIPPING anywhere in the Continental US.
Estimated value of this package including shipping $390
To Enter: Reply to this post and tell us the most creative or bizzare way you have ever seen a satellite dish mounted or transported. Photos available?
Small print:
This contest is open to any SatelliteGuys member based in the Continental US who is in good standing with the exception of Satellite AV staff and members of their families. Contest ends 11:59 pm, PDT, 4/15/2009. One entry per member.
A random drawing of one winner will be made by a member of our staff on April 16th, 2009. If the winner does not respond to our SatelliteGuys PM notification within 10 days, the prize will be forfeited and the unit will be offered to another contestant by random drawing.
This prize will be shipped via a ground freight company to a continental US residence or business address.
________________________________________________________________
GEOSATpro 1.2M ------------- Inverted Mount
Heavy Duty - Built for Extreme Conditions / Easily adapts for top loading motor mounts / Elevation Fine Tuning Adjustment
Shipping Solution
Two units can be shipped together in one shipping box with very little increase in freight cost. A carton fee of $20 (carton, packaging, and strapping) is included in the item price. Shipping cost will be quoted at time of sale. The average cost of shipping is $155 or less to most US addresses. Please note that if you ship to a business address, the cost will be considerably lower! If this item is purchased in bulk, the included $20 shipping carton charge is removed. Bulk orders will be shipped by pallet and a pallet fee of $50 will be applied. The individual shipping carton dimensions are 58" x 52" x 9" and weight is 52 lbs. Up to two dishes can be shipped in one carton with a weight of 78 lbs.
Specs:
Antenna Size 1.2 Meter / 120 CM
Offset Angle 27.3 deg.
Aperture Efficiency 80%
Horizontal Axis 120 cm
Vertical Axis 135 cm
Assembled Weight 27 lbs.
Gain @ 12.5 GHz 43dB
Focal Length 60 cm
F/D Ratio .5 Mount Type U-Bolt Az / El with Fine Tuning Adjustment Azimuth Ajustment 360 deg.
Elevation Adjustment 0 - 90 deg.
Mast Diameter 76 mm / 3"
Operating Temperature -40 C - +60 C
Operational Windspeed 90 km/H
Survival Windspeed 180 km/H
Finish Texture Polyester Powder Coating
Material Gavanized Steel
LNB Mount Type Universal 40 mm / 23 mm clamp
Color Grey
Custom 1.2M Carton Suitable for Shipping
1 or 2 Dishes with Accessories
58" x 52" x 9"
52 lbs - 1 unit / 78 lbs - 2 units
GEOSATpro SL2 - The World's Smallest Dual Output LNBF
Perfect for connecting multiple receivers. The GEOSATpro SL2 Bullet LNBF is the smallest two output Ku-band LNBF available in the world! GEOSATpro technicians incorporated the latest in microelectronic technology to design and produce this innovative high performance twin LNBF. Independent isolated outputs prevent interference between multiple receivers. The small bullet size housing will not compromise signal reception. You will not find a higher performance FSS LNBF anywhere.
Design and manufacturing agreements assure that the unique and high performance SL2 LNBFs are exclusively available through authorized GEOSATpro distributors.
OEM manufacturing of a Standard type with LO 10750 or Universal type with LO 9750/10600 type is available to provide your company with branded distribution opportunities. Please contact Satellite AV to learn more about worldwide or regional distribution.
Specs:
RF Input
I/P Frequency Range 11.7 ~ 12.75GHz
IF Input L.O. Frequency 10.75GHz
O/P Frequency 950 ~ 2000MHz
L.O. Stability +/-3MHz (-40°C ~ +60°C)
L.O. Phase Noise <-50 dBc @ 1KHz offset
<-80 dBc @ 10KHz offset
<-95 dBc @ 100KHz offset
Output 75 ohms F-female type connector
Conversion Performance @ 25°C
Noise Figure 0.4dB (Typ)
Cross Polarization 25dB (Typ)
Image Rejection 40dB (Min)
Output VSWR 2.0:1 Conversion Gain 60dB (Typ)
Gain Flatness +/-0.5dB / 26 MHz, 8dB over each IF band Output Spurious <-60dBm
Power Requirements
Current Consumption 170mA (200 mA Max)
Operating Voltage Vertical: 10.5 – 14.0 VDC
Horizontal: 16.0 – 20.0 VDC
Environmental Working temp/humidity -30°C ~ +60°C 0 ~100%
Mount Diameter 40mm
Length 5 inches (12.5mm)
Weight 4.1 ounces (116.2 grams)
_________________________________________________________________
GEOSATpro CK1 - C-band and K-u-band on one LNBF
GEOSATpro has produced in cooperation with one of the World's leading LNB manufacturer an LNBF that simultaneously receives both C-band and Ku-band linear or circular signals. Expand your viewing options with the ability to view programming from C-band and Ku-band satellites on one dish! Hundreds of additional digital signals are available on these two bands. Hobbyist report success with smaller 1.2 Meter dishes, but we recommend a 2.4M minimum dish size.
Includes standard scaler for 3 or 4 point prime focus mounting and a dielectric insert for reception of circular polarized signals.
Purchase the adapter mount for using with the GEOSAT 1.2M or 1.8M offset dish.
Specs-------------------- C-band --------Ku-band
Input Frequency Range 3.4 - 4.2GHz 11.7 - 12.2GHz
Input Reflector Type Prime Focus Prime Focus
F/D Ratio 0.28~0.42 0.6
Conversion Gain 65dB(Typ.) 55dB(Typ.)
Gain Flatness 1.0dB/36MHz 4dB Over Band/1dB/54MHz
Noise 17°K 0.5dB(Typ.)
Cross Pol. Isolation 20dB(Typ.) 20dB(Min.)
Image Rejection 50dB(Min.) 40dB(Min.)
L.O. Frequency 5150 MHz 10750 MHz
L.O. Stability 1.0MHz@25°
2.5MHz@-40° ~ +60° 1.0MHz @25°
3.0MHz@-40° ~ +60°
L.O. Phase Noise
-50dBc/Hz(1KHz Offset)
-60dBc/Hz(1KHz Offset)
-85dBc/Hz(10KHz Offset)
-95dBc/Hz(100KHz Offset)
-75dBc/Hz(10KHz Offset)
Output Frequency Range 950 ~1750MHz 950~2150MHz
Output Power(at 1dB gain Compression) 0dBM(Min.) 0dB(Min.)
Return Loss Output 10dB 8.0dB(2.3:1)
Output Connector 75° F-Type F 75° F-Type F
Polarization selection H:16~18V:12~14.5V H:16~18V: 11~14V
DC Current Consumption 100mA(Max.) 100mA(Typ.)120mA(Max.)
Operating Temperature -40°~+60° -40°~+60°
Good Luck!
- GEOSATpro 1.2M Offset dish
- GEOSATpro SL2 Dual Output Standard Linear LNBF
- GEOSATpro CK1 C/KU LNBF
- GEOSATpro C-Band Adapter Clamp
Small print:
GEOSATpro
1.2 Meter Offset Dish Antenna
* See shipping information below- Designed and Built to Provide Years of Dependable Reception in Extreme Elements
- Heavy Duty 3" U-Bolt Mounting Bracket Suitable for Post or Motor Mounts / Easily inverted for use with top loading motor mounts
- Efficient / High Gain Reflector
- Perfect for Fringe Area Reception of Weak Signals (outperforms Channel Master and all Competitors)
- C-Band LNB mount available
- Durable and Attractive Grey Textured Finish
- Single Box Packaging suitable for Residential Delivery
- Bulk Quantity Pallet Delivery Available
Specs:
Focal Length 60 cm
Color Grey
58" x 52" x 9"
- Replace a single output LNBF for installation support of 2 or more receivers
- Watch different channels from the same satellite dish on 2 different receivers
- Compatible with DVBS, FTA, MPEG, DCII and Analog satellite receivers
- Stable frequency and low noise 0.4 NR for the very best reception in fringe signal areas
- Twin F-type coax outputs for direct connection with 1 or 2 satellite boxes
- Connect to a standard 22KHz or DiSEqC type multi-switch for multiple receiver connections (3 or more receivers)
- 40mm standard size FSS satellite dish LNBF mount
Specs:
RF Input
Power Requirements
Mount Diameter 40mm
3.0MHz@-40° ~ +60°
L.O. Phase Noise
Good Luck!
