Enter to Win a SatLink WS-6912 DVB-S2 Digital Satellite Meter
Satellite Meter with Real Time Spectrum Analyzer
Retail Price $390
How to enter? Tell us a Back to School Story!
We all have a story to tell about going back to school in the fall. Remember that first ride on the bus or stepping onto high school grounds, starting a new school or getting back together with friends. How about that new hairstyle or the clothes that you had to have? Did you bug your mom to buy that "must have" lunch pail?
Small print:
Tell us as many stories as you wish, but we will accept only one entry per SatelliteGuy Member. This contest is open to any SatelliteGuys member who is in good standing with the exception of Satellite AV staff and members of their families. Contest ends 11:59 pm, PST, 09/19/2011.
A random drawing of one winner will be made by a member of our staff on September 20th, 2011. If the winner does not respond to our SatelliteGuys PM notification within 10 days, the prize will be forfeited and the unit will be offered to another contestant by random drawing.
This prize will be shipped via FedEx Ground freight to any continental US residence or business address. If you are outside of the Continental US, you will be responsible for all shipping cost, brokerage and customs fees.
_________________________________________________________
This is a high quality sample meter provided by the SatLink factory for testing. We decided not to carry the product. Instead of putting it on the shelf to get dusty and eventually be recycled, we will select one random winner to receive this lightly used sample.
Here is some product information from the manufacturer:
Meter Set Includes:
Quickly and accurately align the satellite, instantly check the stability of the channel and view the actual channel on the screen of the meter. Transponders, Frequency, Symbol Rate, Polarity, and other settings can be modified by the user. There is never a need to send your meter in for a upgrade.
Meter never needs to be returned for re-calibration due to the unique calibration system built in to the meter. Each time the meter boots up it automatically calibrates for optimum performance so you can align each install with confidence.
LNB/Tuner input
Connector: F type,male
Frequency range: 950MHz-2150MHz
Signal lever: -65dBm~-25dBm
LNB supply:13/18V,max400mA
LNB switch control: 22KHz, DiSEqC Ver 1.0 /1.1/1.2
Demodulator
Front end: QPSK and 8PSK
Symbol rate: 2Mbps~45Mbps
SCPC and MCPC
Spectral inversion: Auto conversion
System resource
Processor: 32bit processor (200MHz)
SDRAM: 64Mbyte
FLASH:16Mbyte
EEPROM: 8Kbyte
Video decoder
MPEG 2: Main Proflie@Main Level
Data Rate: up to 15M bits/s
Resolution: 720, 576, 720, 480
Video format: PAL/NTSC/SECAM
MPEG Audio: MPEG 1 layer 1&2
Type: Mono
Sampling rates: 32, 44.1 and 48KHz
Serial data interface
Connector: USB type
Power supply
Li-oN Battery: 1950 mA
Voltage: 12.6VDC
Charger
AC: 90 - 240VAC 50/60hz
DC: 11 - 18VAC
Panel connectors
Digital tuner input: F type, male
AV: 3.5MM to RCA
Physical Specification
Weight(Net): 0.5 Kg
Retail Price $390
Small print:
- 8PSK AND QPSK - Fully DVB compliant
- 3.5 Inch High definition TFT LCD Screen which can show live channels
- NEC Solution Chipset
- Shows both S/N and C/N
- Shows Signal Strength and Signal Quality readings
- Sound and Display Lock Confirmation
- Displays numerical reading and bar reading
- Easy Satellite Manager ( EDIT, delete and SCAN)
- Edit TP, Frequency, LNB switch, Symbol Rate etc.
- Completely programmable by the user by direct entry or PC
- Input Frequency 950-2150MHz
- Input Level -65-25dBm
- Input Impedance 75ohm
- Auto Calculate Angle of AZ ,EL
- Upgrade S/W by PC
- Easy to carry, size only 9.5cm X 15.5cm X 4.5cm
- DiSEqC Switch and Motor Control
- USALS Motor Control
- 22KHz Control
- Fast Charge LI-ION Battery(1950mAh), Can Last 4 Hours
- Indicator Lights for 13/18 volts
- Indicator lights for 22 KHz
- USB port for software upgrades
Meter Set Includes:
- Neck strap
- Carrying case
- Wall AC power charger
- 12VDC mobile power charger
LNB/Tuner input
Demodulator
SCPC and MCPC
System resource
SDRAM: 64Mbyte
FLASH:16Mbyte
EEPROM: 8Kbyte
Video decoder
Type: Mono
Connector: USB type
Power supply
Voltage: 12.6VDC
Charger
DC: 11 - 18VAC
Panel connectors
AV: 3.5MM to RCA
Weight(Net): 0.5 Kg
