I'm in Nashville, TN. What size dish do I need to bring in 99W reliably? Also, where does one go to get these C-band LNBs? And are the receivers the same for C-band as they are for Ku?
So Titanium does have a dual output LNB? Then couldn't I hook up a switch with the two lines feeding the 13 and 18 volt ports? Or is the polarity not switched that way with C-band?You can get a dual output Titanium C-Band LNB, that will let you feed two receivers, that might help cut down on the complexity of splitters and the such. I am a huge fan of Titanium LNB's, definitely the way to go.
Titanium does sell a dual output C-Band LNB on his website.
Sadoun has a 6' brand new Prime Focus for $235 shipped. Not bad at all... I don't think that includes any mounting hardware.
@wallyhts, oh. :-( Well hopefully ZanderKoad will locate his website and check out all of Titanium's wares, and watch for when the dual output LNB'S are in stock again soon.
On 99w only If you can live without having livewell network in hd (you will still have it in sd), dodnews and the 2 gdmx syndicated muxes, you can do like I did at my moms. I use a single lnbf with the receiver up front powering the lnbf using a splitter that only passes power on the 1st port. Since everything on 99W other than what I mentioned above is all horizontal any receiver can watch anything that is on.
After scanning in all the channels on the receiver in the front room, I deleted all the vertical channels (those mentioned above) so they could not be selected. Then I told everyone that it had to stay on all the time for anyone to watch tv.
