Connection Headaches
Runr48
Help!
Everything was fine until I rearranged my living room and disconnect the tv, stereo, etc. I labelled everything correctly, so reconnecting should not have been a problem, but it was. Now I have too much reds and greens and no browns and blues. I have a panasonic HDPlasma tv which I connected to my Directv through my stereo receiver. I've checked and rechecked everything, but still can't get those blues and browns. What am I doing wrong? Yes, I checked the connections against the user instructions and still no help.
Where exactly does DirecTV come into this? I think you want a different forum. Besides that, how can we help you hook up something that we can't see, and you provide no information for?
"I have a panasonic HDPlasma tv which I connected to my Directv through my stereo receiver. "
I'm guessing there.
Threadstarter, if you use Y-Pb-Pr cables bypass the stereo receiver and connect them to your TV, that will either prove/eliminate the receiver being the problem.
I'm guessing there.
The problem is that he has too many cables left over of one type (color) and not enough of another type, which is what I mean by it not being a problem related to DirecTV. The problem is he did not mark down where what went properly (even though he thought he did). :)
EDIT: Or is he refeerring to colors on his TV? Either way, the OP needs clarifying.
It sounds a lot like one component videl lead is loose. Check the component input cables between the D* IRD and stereo rcvr, and also the ones from the stereo rcvr to the plasma screen. Somewhere you have a BLUE lead that is loose.
I have had this happen. One lead looks like it's connected but is loose. Just push it in snugly.
This is what I would look for as well, even though it appears to be connected, unplug them all and reseat them.
I am presuming you are going from the D* receiver to the TV with your R/G/B cables.
Jimbo
Signal Tweak
"secret ebay info on HR10-250"
