I have had Dish for about a year and I am wanting to put a TV into an additional room in my home.
My setup is this:
I have two recievers... both are dual tuner.
I have purchased a single tuner (the 311) for the seperate room.
Off of my Dish 500, I have two cables. Each cable runs into the room where each dual tuner reciever is. at the reciever, there is what I call a splitter for lack of better knowledge of the terms.
I've thought I read I could do this by purchasing a DP34 so I did.
I have both leads off of the dish plugged in correctly. I have room #1 with a dual tuner plugged into the out to tv port 1 on the DP34, as well as # 2 going to room 2 (dual reciever).
Both dual recievers are giving switch errors. When I test the switch on one of the recievers, I get TV1 with only one of the sats, but the TV2 with both... next time I run the test, I get different results. After running the test 3 or 4 times... I gave up and came here.
Any thoughts? Oh... once this is working, I still want to plug # 3 port into the cable that is running to my new reciever.
Thanks!
My setup is this:
Thanks!
