I am one of the dumbest people that uses a computer but someone told me that they purchased their computer from a flea market 20 years ago and that it has not been updated other than a color copier and uses it on the internet. Is this Possible?
It is possible.
Well the OP did not mention what architecture or OS, but email was invented in 1972, there was the Arpanet ~1962, all required equipment that would/could get it on the internet, i.e. IBM PCs had serial ports, which is the only thing required for an (even modern) external dialup modem (which btw, modems have been around since the 50s').
Before windows, DOS supported internet connectivity by slip/ppp using things like Trumpsock (prewindows and pre winsock).
Tell me what ISP still supports slip/ppp. I got the question being that the person is still using it on the internet today. I do not know any provider that will still support things from the 80's. Even with the serial port the PC's from the 80's did not have one that would support the speeds of todays modems. Also how many PC's would you have found at a flea market in the early 80's. They still cost a pretty penny at that time.
Well first let me clarify, I am not defending the OPs friend, I am just answering queries to the best of my ability, if I were you I would be doubtful too, but not because it is not possible (because it is), but because it's very unlikely.
Now to your question, when I said slip/ppp, that was referring to the way they would/might have had to connect back then, TODAY, he could just use his ISPs DSL/Cable router which does the actual handling of the connections, and any old ISA ethernet card (remember lanman?) would do (transfer speeds would be severly limited due to CPU/RAM considerations), or, if he says he is using a dialup modem, many (many many) ISPs support SLIP connection, far more than I could list here.
Fact is, the internet predates 1986, which means the computers of that time had the ability to network (if it had a serial port, it could be connected), and therefore could participate on the internet, albeit slowly.
I know that you are not defending his friend. I still do not find it next to impossible in todays world.
I still do not think that you could get a ISA ethernet card to communicate through a cable/DSL router. the 10baseT standard for ethernet did not even get created until the early 90's. A PC from the early 80's would not even have enough memory to load the driver in DOS.
Bless all of your hearts for responding. They told me basically off the the shelf 20 years ago from a flea market. Ain't no way. just wanted a freind that did not want to believe this was bs to hear it from someone else.
damaged said:Additionally, there are plenty of UNIX machines that are 20 years ol, that are in the internet to this day, windows is not the first computer system.
You are the one that stated that he could use a Cable/DSL router to connect today.
All I stated was that the ethernet standard that was used to connect to todays network was not created until the early 90's. There i a big difference in the drivers that were built in the 70's and 90's. The drivers in the 90's took a lot more memory than the ones in the 70's. And by the way ethernet standards were first created in 1973.
Don't forget this talk is about a PC not Unix system that was purchased at a flea market. We are not talking about high end systems at that time.
I will give you that it is possible to connect to the internet but you would not be able to do anything today.
I to have been working in the industry for a long time. Not as long as you but long enough.
This person tries to show people that they do everything on their own but abuse their family. Does not give their family any credit. I know the computer was purchased two years ago for them by their mother who does not know much about computers.. Sad....... Maybe I should not have said anything but I am so tired of them doing or saying things like this. Just wanted someone else to say it. It's like saying I purchased a 52" HD TV 20 years ago. Oooookay.
That is all I have been saying, but you seem to have this idea that I am saying things I never said, (even though you say you are not, you still seems to be thinking I am defending this guy).
I guess a good debate is thinking that you are defending him. You are giving people way to much credit. There are not that many people that would ever think of doing what you have said (or would ever want to).
By the way their is not much homework to do. I guess you think I am an idiot because I like talking in terms that most people would understand. I am used to dealing with end users and managers that would look at you with a blank stare if I talked to them the way you have.
