composite and DVI
robert
5
Is it possile to connect two different tv's to Voom receiver, using Composite and DVI ? I realize both would be viewing the same program. Thanks
I think that's possible, since all outputs are active at the same time. But you would be limited to the length of your cables. I have 4 TV's running off the same STB, using the coax out connector on the STB to feed to a splitter that sends the signal to 3 TV's, and the main TV is connect via component and DVI/HDMI. The coax out is limited to a signal of 480I, so it's not true HD.
Yes, you may. I have DVI going to my pj, Component to a switch box, S-Video to my DVD recorder, Composite to my Commodore monitor and coax to another room and all are hot at the same time, works great!
Why is Fox signal fading in and out???
TNT HD Question on PQ & Blackouts
