Component to Composite?
mewilsie
67
Black Earth, WI
I was wondering if there is a coupler, or similar device that makes it possible to hook up a TV with only composite inputs to a device with component outputs?
What I want to do is hook up a HD/DTV box to my old TV that only has composite(RCA) inputs. The HD/DTV box has composite outputs, but I've read that the OSD doesn't work unless you use the component or HDMI output. The box I'm looking at is the Samsung DTB-H260f.
Any help would be great.
Wow! Might as well buy a new TV for that cash.
Does anyone know if you can use the subtitles/closed captioning if you're using the composite output on the Samsung box?
Solid Signal down?
samsung sir-t451 "vs." samsung sir-ts360
