Over the course of the last few days, I've been looking for a way to combine the output of two receivers into the output of a second multiswitch that will feed all of my bedroom receivers. Here's how I want to lay it out... I have a dual-LNB dish with a 3x4 multiswitch after it. For the sake of simplicity and to make the task a bit cheaper, I am going to cascade another multiswitch (3x8) from the first. On that first multiswitch is a DirecTivo that I want to "Channel 3" on the TVs on the second multiswitch (using a diplexer for each set). Here's where it gets complicated.
From the second multiswitch, I want to connect two regular receivers and two DirecTV+ DVRs. I also want to take the output of one of the regular receivers and have it inputed into multiswitch #2 as "Channel 4".
I've pretty much figured out how to setup eveyrthing, but I don't know how to combine the two signals without getting a crappy signal. I've tried it once before a few years ago with two regular receivers and an el-cheapo TV splitter connected backwards, but all I got was a terrible picture on one channel and static with a hint of sound on the other. I'm not sure if that's because one receiver was 10 feet away and the other was around 100 (in cabling), or because of the splitter, or some other reason.
So please, does this make sense, and is it possible?
TIA!
TIA!
