This is becoming increasingly dangerous as DOCSIS frequencies expand into satellite's IF territory and satellite's use of MoCA becomes more prevalent in DBS installations. Using diplexers with DIRECTV has been a no-no for several years.I use them often to combine a cable modem and satellite tv connection
Your only considering the problems that existed five years ago. More recently, each service is encroaching further into the bands used by the other. DOCSIS 3.0 (cable modem) can go up to 1GHz now and cable MoCA goes up to 1.5GHZ or so.That's because they band stack. Otherwise, not a problem. Just know which frequencies you're working with.
That's kind of like leaving someone with a car and telling them the gas gauge doesn't work.So as long as they don't conflict, you're good to go.
really?Using diplexers with DIRECTV has been a no-no for several years.
Really. Back in the day, the parameters were better known but as time progresses, things are less certain.really?
really?
Then tell that to Access Media 3. When I lived in my apartment there was only one line running from the junction box to the apartments and they used diplexers all the time to bring both Crapcast internet and Directv into the apartment
Well this is about as clear as mud.If you've got a contract with the cableco, you might be able to write some parameters into the contract that will allow you to do things that others cannot safely assume. WIthout that ability, each provider will eventually take over most of the bandwidth.
Suffice it to say that the cable company is not compelled in any way to make provisions for any existing loopholes that individuals might choose to use their coax for. They will likely put a punitive stop to anything that interferes with the delivery of services to other customers.Well this is about as clear as mud.
