Combine single and triple dish signal
BarBQd Iguana
5
Here's my dilemma. I live in a neighborhood with lots of trees. I have a small hole that will allow my Triple LNB dish to pick up only 2 satellites (101&109 or 109&119). I also have a single LNB dish that is picking up the other satellite. What do I need to run these two dishes through 1 wire? Because the 3 LNB dish has a built in switch can I add another after it? Or, if anyone else has an alternative idea that would be great. I thought about removing an LNB from the 3 and running a wire from the 1 to that spot. But, the 3 dish looks too sealed and I don't want to break it. Right now I have an A/B switch that I have to run outside and push to change between satellites.
Thanks for any help.
Get a cascadable switch, like a 4x8.
Point the oval dish @110/119 & run 2 lines from it into the 22khz inputs.
Point the single dish to 101 & run those 2 lines into the other 2 (non-22khz) inputs. (of course, your single dish will need a dual-out LNB)
Hook up your receivers to any of the 8 outputs on the switch & you're good to go.
Using a Diplexer
Programming Universal Remote for R10
