kurtsat said:They do have but VERY expensive.. I'm not sure how much is expensive..
What is the name of the receiver? I would like to research it a little.
wantogetstarted said:What is the name of the receiver? I would like to research it a little.
PSB said:They can be had VERY cheaply these days and can be slaved to a DVB receiver.
4:2:0 and 4:2:2 (or any other chroma ratio) are only descriptive of digital signals. These do not apply to analog signals.satcustomer said:And are the analog feeds something like 4:2:0 Analog instead of 4:2:0 Digital? Aren't most feeds digital or even 4:2:2 Digital?
briansanders007 said:Is there any way to get this game? only on mediacom cable?
Toledo at Iowa St. (Mediacom-Iowa) 8pm
PSB said:Most college feeds seem to be analog so you would need an old analog receiver. They can be had VERY cheaply these days and can be slaved to a DVB receiver with a short RG6 coax run.
yes. But one catch...same polarity on the same satellitea_hockeynut said:I am very interested in how to accomplish this. I have a fortec classic NA (which has a loop out to connect another reciever), and a motorized dish. So if I hook up an analog receiver to the loop out, I presume I can point the dish with my fortec, and get channels from the same satellite analog?
nope. Same LNB can do bothNo different LNB needed?
correct.And I can have both receivers decoding a signal at the same time (so I could have a TV hooked to my fortec watching digital, and another TV hooked to the analog watching analog)?
99% of the analog channels on KU are feeds (come and go). Weekends are the best to find the analog feeds (sports)Where would I find a list of "analog" channels for a satellite? Currently I look here for the list of channels: http://www.global-cm.net/MPEGlistKuBandUS.html
Iceberg said:yes. But one catch...same polarity on the same satellite
no. Part of the issue is the older C/KU analog boxes can't control polarity. If you hook it directly up, you get H side only. If you turn off the Fortec, it defaults the analog back to Ha_hockeynut said:Is there a way around the "same polarity", like can I turn off my fortec, or does it need to be on to "pass through"?
I can watch 2 things (one analog one digital). There isnt much on analog (sports feeds) and with only 24 channels its pretty easy. When I'm blind scanning a satellite, I flip over to nalog and scan one side and when the digital box starts canning the other polarity, then I scan the analog againThen I guess I am only watching from one receiver, but if I am limited to same polarity I am not sure how I would find the feeds on a given satellite without knowing the polarity (I like to be able to just scan them all and find them, blind scan is wonderful!).
there are some. Most WCHA games that are on FTA are on digital but some east coast teams do still use analog (at least last year they did)I am very interested in finding sports. Of course I am mostly going to be interested in hockey games. Are there many hockey games which are on analog?
the only difference between an "old" and a "new" analog is the old were C Band only. As long as it can get KU you're fine. That box may be C-Band only. Is there anything on it that allows you to flip to KU Band?I have a very old analog receiver (was a giveaway on freecycle) which I have no clue if it will work or not, but hey, it might be worth a shot. On the front it says "SAT-COM 240 satellite receiver", and has one dial for video, and one dial for audio. My only concern would be it might not have the range of channels which a "newer" analog receiver would. Thoughts?
Iceberg said:That box may be C-Band only. Is there anything on it that allows you to flip to KU Band?
