Thanks Guys, I'll check them out. I knew that I could check for continuity with a Volt/Ohm meter but do not know, if there is a small short, say just one wire from the shielding to the center conductor will that show up? Or would it be so small that a V/O meter may not be sensitive enough to see it? I'm sure that a small short would affect the signal but not continuity? Part of my reason for concern is that I'm an installer for Wild Blue Satellite internet, the coax and connections all have to be rated at 3Ghz and the WB signal is very sensitive to the cable and fittings. There has been a lot of talk about bad connections, bad cable etc. on other forums, I would like to find a tool to help me in the field troubleshoot possible cable issues. Thank You for your help and I will follow any leads I see here. Ron
