Today I did a comparison between CNN HD on DirecTV and the newly added CNN HD on BHN.
My hookup-
I currently have my BHN box hooked up via HDMI (looks better than component on my Sony HD set) and my fairly newly subscribed DirecTV box (about six weeks) is hooked up via component still (I have an HDMI 4 device switch on the way for both HDTVs). Having had both BHN and Dish Network, I stand behind the HDMI looking better than component on this particular Sony HDTV with any tested source (including Xbox360, Dish Network 622, BHN HD box). I have not yet hooked my DirecTV H21 up via HDMI. But in general, HDMI is known to look better than component (I realize not always) but this has been the case with my Sony HD television.
The comparison-
I tuned to CNN HD on both my BHN box and DirecTV. I then switched back and forth between video inputs, in a non-scientific eyeball examination of CNN HD on each source. Keep in mind, DirecTV is using the component connection, which in general looks worse on this television.
The Results-
1- CNN HD on DirecTV is about 5 seconds ahead of CNN HD on BHN. I'm not sure why BHN has such a delay.
2- CNN HD looks far better to the naked eye on DirecTV than it does on BHN. In fact, I got macroblocking on BHN during my trial. But even when it wasn't pixelating, the BHN picture was washed out and not nearly as sharp.
My thoughts-
I hope this is not a sign of things to come with BHN once they start using SDV (if this isn't SDV already). It is entirely possible they are feeling pressure to add channels and reducing bandwidth (think HD Lite) in order to squeeze in channels. I often (almost always) found BHN HD to have a better picture on the same channels as Dish Network HD last year when I subscribed to both, but that is clearly not the case when comparing DirecTV to BHN. DirecTV is far better to the naked eye. I'll test again when I have both hooked up via HDMI later this week and compare some other channels. DirecTV looks great now, it should be even better with HDMI.
Your thoughts-
Anybody else do a comparison test yet? How about BHN vs. FIOS. Oh wait, I don't think FIOS gets CNN HD yet. But you could test other channels.
My hookup-
The comparison-
The Results-
My thoughts-
Your thoughts-
