here's a guy who actually measured the net gain on the cm4228 for vhf ch 7-13
http://www.hdtvprimer.com/ANTENNAS/comparing.html
see net gain...cm4228 in dbd (up and down) - most antennas are measured in dbd...but look out in measurements in dbi=dbd +2.14
ch
7 0dbd
8 -4
*9 +3
*10 +6
*11+5
12-2
*13 +4
lets compare gain just on ch 9 (middle of band and a commom ch. measured by the manufacturers)
uhf only antenna examples from graph
cm4228 +3
pr8800 -3
cm4221 -14
db8 -19
sharpshooter -11
squareshooter -22
vhf/uhf combos - from mfg. specs.
winegard
hd 7080p +9.5
hd7082p +10.9
hd7084p +12.0
hd8200p +12.6
channel master - from mfg. specs
cm 3016 +8.7
cm3018 +9.0
cm3020 +9.9
cm3677+8.0
cm3679 +7.9
cm3678 +9.6
cm3671 +11.0
ch 7-13 vhf yagis - avg mfg. specs
6 element +7
13 element +10
for ch 9 ... on paper looking at a chart and a graph
cm4228 +3.
to put things into perspective...
-we are talking silver sensor/ square shooter uhf type performance for ch 10, 11, and 13 vhf with the cm4228... look at the net gain on the chart for these antennas (Just to give a reference some may be familiar with).
-ch 9,10,11, and 13 are in the positive...all others are kinda low and others negative.
-the dips on the graph are real deep and narrow...this means if the testing was off even a tadd, the dip could be moved to the left or right affecting performance.
-from the gain levels we are probably talking yellow, green, lt green as ok...going up to red , blue purple, the results success should lessen
-***the variables associated from user to user differ and affect performance...terrain, height above sea level, transmit powers, line of site, home construction materials (for attic installs), etc. , etc.
so yes, there are going to be reports of good reception...and there are many... and there are even some bad.
In general, antenna performance with dbd of less than 6 dbd can be considered marginal.
What does marginal mean?
-subtract coax losses
-subtract splitter losses
-subtract signal losses if installed in an attic
-subtract misc. factors that are not easily determined
The net result does not leave much gain.
The numbers above offer a comparison using a consistant form of measurement. And we never see it layed out in black and white...and it made more sense to me when I laid it out on paper.
This information is not intended to say that the cm4228 stinks. It is a great performer.
The variables mentioned above *** are giving us the variation in reception...and the pissing matches we read at the forums.
Please feel free to comment...
ch
7 0dbd
8 -4
*9 +3
*10 +6
*11+5
12-2
*13 +4
cm4228 +3
pr8800 -3
cm4221 -14
db8 -19
sharpshooter -11
squareshooter -22
winegard
hd 7080p +9.5
hd7082p +10.9
hd7084p +12.0
hd8200p +12.6
cm 3016 +8.7
cm3018 +9.0
cm3020 +9.9
cm3677+8.0
cm3679 +7.9
cm3678 +9.6
cm3671 +11.0
6 element +7
13 element +10
cm4228 +3.
