Cleveland WLFM-LP now has a Digital app for Ch. 6 and..
jxg0754
SatelliteGuys Guru
137
6
ohio
Cleveland WLFM-LP now has a Digital application for Channel 6 was filed on 11/25/13, and i would love to see the Longley-Rice Coverage Map for W35AX for the Channel 16 Amendment Application along with WLFM Digital Application
Thank You
sorry i was not more specific
sorry i was not more specific, WLFM is currently not listed on RabbitEars cleveland market,and also i was looking for the Longley-Rice coverage map on the RabbitEars TV Query like this here which was for the original W35AX application, I want to see the Amendment one for W35AX which is not currently on the RabbitEars TV Query and the Digital Application for WLFM i just do not want to see the contours for the stations which are here W35AX Amendment Application and WLFM Digital Application
Thank You
In the RabbitEars TV Query, if you click the little transmitter tower icon in the "Map" column, it will take you to the Longley-Rice map for that record.
http://www.rabbitears.info/tvq.php?city=Cleveland&state=OH&request=list
Here are the direct links:
WLFM: http://www.rabbitears.info/contour.php?appid=1599928&map=Y
W35AX: http://www.rabbitears.info/contour.php?appid=1576100&map=Y
The amendment has the same filing number as the original application, so the map was redone for the amendment but the filing number is the same.
Let me know how else I can help!
- Trip
Thanks, but for W35AX that looks like the old contour, the second one is the amendment application, if you are running a script by an chance is it just going by the first one, and WLFM is not yet listed in the Cleveland Ohio market it used to be there but it is no longer the link you provided is the only direct way to the longley-rice coverage map
Thank You
WLFM is an analog station and even though they've filed to go digital with it, since they're using it as an FM signal, I don't expect to see it go digital until the last possible moment. As such, I am going to refrain from listing it with the Cleveland TV stations for the time being.
W35AX looks the same as the old record because the amendment doesn't actually change the power, height, or antenna, the amendment just asks for additional waivers.
- Trip
i am sorry about W35AX i just read the waiver request for the amended application, it actually according to W35AX should have been approved years ago and earlier this year if it had the chance to submitted an actual interference study that they were not aware of until February 13th 2013 when they found out Canada approved their application on May 13th 2011 and then there was a Freeze placed on Class A modifications
The freeze doesn't apply to conversions from analog to digital, so that shouldn't impact the W35AX permit being granted.
- Trip
