what TP do you use to allign to 87w?
Solid versus CCS comes down entirely to how much the current draw is on the dish end of the cable. I doubt that it is all that important in the FTA world as the LNBs tend to be pretty efficient. It is when you have a bunch of switchgear hanging out there (especially with DIRECTV or perhaps satellite Internet) that higher ampacity comes into play. CCS conducts signal just as well as SCC but steel (3-15% of the conductivity of copper) isn't nearly as good for ampacity when it comes to conducting DC power to run switchgear.Is it important to purchase coax that has a solid copper core?
How often do you want to have to trim back 2 or 3 inches on the ends when the center core rusts?Is it important to purchase coax that has a solid copper core? There are so many different types, even among professional, burial and aerial grade coaxial cable.
Buy solid copper, seal it well, and be done with it!
Now I just need to follow my own advice!Yep. I bought 50 feet of dual solid copper core coax to feed my 90cm dish feeds, and then tonight ordered 75ft of solid copper single coax to feed the 75cm dish on the roof. I figure it’s best to do it right the first time and save myself the headaches later.
Unless you're using the cable to power something significant at the dish end, resistance is of little consequence and doesn't materially impact the signal transmission properties of the cable. Anyone who wishes to understand why (and maybe even if you don't) should read this Wikipedia article:Resistance difference is noticeable in the short term.
Commscope/Belden I think is the same company, but there are different types of RG6 they sell so make sure you obtain what you require; solid CU versus copperweld center, etc. Very rare to have problems with their feedlines whatever the type.
This is comparable to pretty much any "legacy" pizza dish setup. When I refer to complex switchgear I'm talking about the likes of SWM where the power consumption of the LNB can be relatively high. In the case of the DIRECTV PI21, it is rated for 25 watts. The old-school DIRECTV switchgear was less than 10 watts. The DISH DPH-42 maxes at 365mA.And since the LNBF's and the switch both require power, I decided to invest in solid copper coax to help cut down on loss.
Legacy systems with more than 2 LNBFs typically had a powered switch.
Running a motor and or switches and multiple LNBs at the end of a long run at 13Vdc and typical 300-450mA is an apples to orange comparison to a SWM power inserted running 21Vdc at 1.5A. A motor and two LNBFs typically exceed the maximum current rating of any FTA STB.
Another consideration is the shielding for reliable DiSEqC signaling. I only use solid copper core quad shield.
Depends what the current requirements are for the components. Not the rating of the coax, but rather the STB.
