I'm getting the following error when trying to checkout on the Glorystar site. Seems a bit odd and a bit disconcerting as well. Using Firefox 3.
Anyone else have a problem?
Secure Connection Failed
www.glorystar.tv uses an invalid security certificate.
The certificate is only valid for the following names:
*.poweron.com , poweron.com
(Error code: ssl_error_bad_cert_domain)
* This could be a problem with the server's configuration, or it could be someone trying to impersonate the server.
* If you have connected to this server successfully in the past, the error may be temporary, and you can try again later.
