Check switch error
tsduke
1,624
Iowa
Anyone know what this mean in the details after running a check switch?
Under Satellite input 2:
[T1] Invalid DishPro Switch detected, Code 15,A1
Otherwise everything check and seems to work ok.
It is due to the fact that your installer did not install a good DPP LNB. I had the same problem and called dish back out and all is good. He even peaked 129 wich was a miserable 50 before now at about 63 for the lowest TP.
I haven't noticed any big problems yet. I do have some lower readings on 129(50's and 60's), but yesterday TP30 was at 81 when I looked.
I talked to Dish support. Said not to worry about the error code in the check switch unless other problems or errors ocurr.
On a side note: I got a really nice gal on tech support line. I could understand her and she was actually quite pleasant.
I just sent the the 622 team an email on this just in case it's 4.01 related. I got a message saying error detected, run check switch.
Got these 2 error lines in the details.
Input 1 - [T0] Invalid DishPro Switch detected, Code 15,A1
Input 2 - [T1] Invalid DishPro Switch detected, Code 15,A1
Used to only be on one tuner input.
New HD installation questions
Wow what a difference!
