Downloaded and installed the channel editor for the S9. Having a problem. Maybe due to doing something wrong? What I did was to dump the TP_PROG.dbs from receiver. Opened file with editor. Clicked on a Sat and right side showed the channels. Double clicked on a channel to edit name. Noticed only name, channel type, ID, group, scramble, factory, and audio mode were something you could change. Vid Pid, audio pid1, 2, and 3, with pcr pid were all grayed out, not changeable. Change a channel name and small window pops up that states Audio Pid is invalid. Click on OK and Pid is set to zero. Not good if you are going to put file back into receiver and have audio pid at zero.
So what could be wrong?
RT.
RT.
