I have four HR20s but existing SlimLine 5LNB is too limited for all the dual tuners. I seem to recall in my dim memory from past forum traffic that there is an issue with off-air guide info if I only have the 99, 101 and 103 satellites (SWM3.) Does the regular D* guide still contain the off-air program info from the 99/101/103 satellites or is there some requirement to pull it from the 110 or 119 satellites? I have verified that all my HR20s have the FTM capability on SAT 1 input so think I'm good to go for SWM.
I'm pretty technical and assume I only need to change the LNB, add an appropriate splitter and power supply, and reconfigure each receiver to the SWM mode. Would appreciate any help as the off-air capabillity and channel guide info is important when weather interrupts satellite service.
