CE Release for HR2x & R22 5/22 v.0315
Rey
@ your service
27,003
585
Florida
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
Friday 5/22/2009 11pm - 2:30am ET
Saturday 5/23/2009 11pm - 2:30am ET
Notes from DirecTV for this release:
Version 0x315
HR20-100, HR20-700
HR21-100, HR21-200, HR21-700
HR22-100
HR23-700
R22-100, R22-200
Improvements & Updates
* Spontaneous reboots
* Box unable to boot after CE download
* Lost audio after CE download
* Play button activates trickplay bar in ScoreGuide channels
* To Do List and History info screens
* MRV client playing back ATSC recordings
* DoublePlay after exiting recording
* Loss of background in interactive apps
* Under the hood
Notes
* No keyword needed for DoublePlay
* You will lose your guide cache when reverting from CE to national
* High Risk Download
* When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
Previous Release Information:
New features
01 - Multi-Room Viewing (enable with keyword search "MRVCLIENTON")
01 - Faster Reboots
03 - Dual Live Buffers (no longer requires keyword search to activate)
Improved/Updated
01 - Program Guide refinements
01 - Under the hood
01 - UI polishing
01 - 20 actors available again in listing
01 - Faster Guide
02 - DIRECTV On Demand in native mode
02 - Playlist sorting
02 - Prioritizer deletion
02 - Previous channel when exiting interactive
02 - Under the hood
03 - Fixed frequent rebooting introduced in CE:20:02
03 - Missing OTA Channels
03 - No Guide Data HR21-200 only
03 - MediaShare: Tversity subfolder playback
03 - Under the hood
04 - Fixed long time to get out of standby
04 - Dual Live Buffers (GameSwap)
----- Resolution issues when switching buffers
----- Scheduled recordings will default to background tuner when there is no response to conflict resolution dialog
----- New information message when activating
----- Deactivates after 2 hours of non-use
----- Deactivates by putting receiver in standby (turn off) for 5 minutes or more and then turn it back on
----- Removed Toggle Tuner menu from TV Options (Yellow Button)
04 - Reboot issues
04 - Black Screen
04 - Under the hood
05 - Receivers not getting software download
05 - Keep or Delete OSD upon playback
05 - DoublePlay: Channel banner display
05 - MediaShare: Unable to play videos
05 - Reboot issues
05 - Caller ID
05 - Record Series Conflict screen
05 - System Test
05 - Under the hood
06 - Trickplay to Normal Play speed
06 - No Audio on Local channel recording
06 - Audio on Mix channels
06 - MediaShare compatibility with media servers
06 - History and To Do List recording messages
06 - Record Series confirmation messages
06 - Booking live program recording prompts to add end time extension
06 - 1080p/24 TV compatibility
06 - Under the hood
First time attempting CE, and so far it's been painless.
MRV works between an HR21 and an HR22! Yay! I did IAMANEDGECUTTER, POKEEYENOW, MRVCLIENTON and YOUASKEDFORIT.
I was under the impression that there was going to be a menu item somewhere to set the name of the MRV "server", but all I see are SID numbers. Since we only have two DVRs, it's unambiguous, so it doesn't bother us.
The first remote play attempt failed, but the 2nd ones and subsequent ones worked.
So far seems good. Guide very fast and responsive. Will test TVersity in the AM, to tired to muck with it tonight
I have started up MRV. It is showing the receiver ids under list. Can I change that to a more descriptive name.
go to Menu-> Setup-> System Setup-> Network-> Advanced Setup -> Enter receiver name using number keys on remote ... when finished select connect now, go to your HD Receiver and instead of RID # you should see receiver name. Worked for me with no problems.
Successful upgrade of all receivers. double live buffer works flawless, MRV on HD works flawless, no hang-ups. Video/Audio smooth, everything working fine so far
If you go to Network and then Advanced you can name you receiver. Just got an owned HR20-700 to go with my HR23-700 and MRV works great, named receiver comes up. I even tried dual streaming and it worked well too.
the mrv on my H21 in the game room is workin' out great ... now i can hide from the wife, and watch my "first 48 hours" ! lovin' it !
All seems to be well. Got the missing locals I had a couple of weeks ago back. I am glad since I was the only one apparently having that issue on here.
HR21-100 with AM21
GUI speed is better than most of the previous releases so far. I will put it through its paces over the next few days and report back since some GUI slowdown/issues seemed to appear in previous CEs after about 3 days of use.
CE's for 5/29 & 5/30
31A: MRVCLIENTON hangs ui
