CE bug?
goaliebob99
14,487
521
Masterdeals can you forward this to D*
I am having issues where my reciver is stuck in 480P mode. It no longer works with native resolution. WHen I take it out of native rez mode. I can flip to 720P, 1080I, ect. But when its in native rez mode. It wont flipp to the native rez of the channel. It stays in 480P mode.
Ok all seems to be fine now, the fix is to take your reciver out of native mode, reboot, and then put it back into native mode. All seems to work fine after that. :) This maybe something that D* may want to look into if they have time.
Did you try using the format button until it was on "as broadcast"?
They added that a few cycles ago and if it isn't on as broadcast the format button will override the native setting.
Yes, when it was on as braudcasted, the screen was in wide screen like normal, but it stayed in 480P mode, even though I was watching a channel that was braudcasted in 720P. When I flipped to an 1080I mode channel like HBO or Starz, It stayed in 480P widescreen.
Games advertisements in the guide
R15-500 CE Release 2/22 & 2/23 0x1194
