I just compared a Cband DMX741 and 242 with a 241 lnb and made a couple of observations which I'd like to better understand. On the inside of the lnbs, there are 3 rods, 1 thicker one that goes all the way accross, and two smaller ones which protude into the lumen. The thicker one and one of the thinner ones are the same plane whereas one thinner one is 90degrees.
On the 241, the thicker rod points to the "O" setting marked on the lnb and would appear to be oriented vertically.
On the 242 and 741, the thicker rod is oriented 90degress from the "O" and would appear to be oriented horizontally.
Could someone explain the apparent 90 degree differences?
